Ana içeriğe geç
Kasım 2006'da Kuzey Amerika'da piyasaya sürülen Wii, hem çevrimiçi oyunları hem de Wii Shop Channel üzerinden oyunların ve medya uygulamalarının dijital dağıtımını destekleyerek internet bağlantısını doğrudan destekleyen ilk Nintendo ev konsoludur.
Problem With Wii? Can Any body Help?
My Wii Turn Off After I Play The Game For 15 - 30 Minutes And when I switch it on again and play the Game Again It Wont Start And Turn Off Again.Then After 30 minutes it work again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
i would say you need to turn it on and look in the back. i would bet your fan is not working. its a easy fix to do your self i have repaired lots with this issue . you may be able to stick a toothpick in there and bump the fan to get it working again. but i would replace it as it is going bad ;)
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Sounds like overheating, but when game does not work in like 30 minutes, it may be two things.
1) Game disk if you play games what you get from game stores OR Flash memory if you play downloaded virtual console/wiiware games.[
2) Do you have problems with other games? If not, it can be the optical drive.
If you have warranty left, take it to nintendo to be repaired.
If you don't have warranty, here is a link to an new wii dvd drive:
Wii DVD Drive
Replace a broken or damaged optical drive compatible with a Nintendo Wii game console. Görseli
Ürün
Nintendo Wii DVD Drive
$29.99
Puan 2
Yorum Ekle
See if anything is blocking the fans movement. It could be your system overheating. If so, this must be addressed as this is a fire hazard
Puan 0
Yorum Ekle
Yanıtını ekle
Azlan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 3,133
