Ana içeriğe geç
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
87 Soru Tümünü görüntüle
Is this logic board fixable?
Hello everyone,
Liquid entered my 2019 MacBook Pro 15" Touch Bar through the fans in the back and the following area of the logic board seems to have been burned (the case even contained black smoke mark). I’ve attached an image.
Is this fixable? Will I wil be able to retrieve my data otherwise?
Thanks in advanced,
~N
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The damage is part of the backlight power logic. This might be repairable! The reason I can’t give you a hard answer is it depends on what else is damaged and what is left of the traces. This will require some delicate surgery to repair.
As far as gaining access to your data on the system that too might be possible! You’ll need access to a second Mac which has Thunderbolt3 ports. Here we are going to leverage your systems ability to act like an external drive using Target Disk Mode:
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you. Nothing else seems to have been damaged. I've emailed Rossman Repair Group to see if the are able to fit it. If not I will try booting it up in Target Disk Mode and retrieve the data.
tarafından
Yorum Ekle
Yanıtını ekle
Nicolas L sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 79
