You did take the battery out before cleaning the fan, right?
Probably a connector was not proberly reconnected or was already loose during the re-assmbly.
Just recheck everything.
Here is the HP Service Manual:
http://h10032.www1.hp.com/ctg/Manual/c02...
There are a number of HP EliteBook 2530p disassemble videos on YouTube.
Now to make things clear. Which lights are you referring to?
Lights on left front:
- Wireless light - Blue=on; amber=off
- Power light - Blinking=sleep or standby; On=On; Off=Hibernation or Off
- Battery light - Amber=Battery charging; White=close to full charge; Blinking Amber= battery low with charger unplugged; Off=battery is fully charged when charger is plugged in.
- Drive light - White=drive is being accessed; Amber=drive parked by 3D DriveGuard
Number of Blinking CapsLock/NumLock or Beeps:
https://h30434.www3.hp.com/t5/Notebooks-...
New:
Have you tried resetting the BIOS?
Turn off laptop.
Unplug charger/power supply.
Remove Battery.
Open case and remove CMOS coin battery.
Press and hold power button for 20 seconds.
Put CMOS battery back in.
Plug in powersupply/charger
Press power button. Does it turn on?
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
7 Yorum
yes i did removed the battery mike, thx for your answer..))
actually my device is an 2540p, i choosed 2530p since there was no 2540p in the options when i was submitting the question, anyway..
i did rechecked every connector as you suggested. now the behaviour of the led has changed: power led stays blue for 3 seconds and then fast flashes blue for 11 time or so then it turns yellow for half a second and it goes away. this happens only the adaptor cable is connected; when there’s only the battery, power button does not do anything.
does this mean anything new to you?
regards
umut tarafından
@umt
Manual refers to your "Blue" as "White" but yes it does look bluish.
Does nothing appear on the screen at all?
mike tarafından
@aactech no, nothing at all
umut tarafından
Hi @umt
I edited the answer below. Let me know about the lights including "Number of Blinking CapsLock/NumLock or Beeps"
mike tarafından
Your Q: Which lights are you referring to?
I’m referring the battery led.
Power button pressed when the battery is in place and the adaptor is connected: The led is amber for 2 sec, then starts flashing for 3-4 sec and goes off.
Power button pressed when the battery is in place and the adaptor is DISconnected: Led is off at all.
I appreciate your responses. nevertheless, i’m getting convinced that there’s something damaged and i should take it to a service shop..))
kind regards
umut tarafından
2 tane daha yorum göster
