Water under screen after spill, leaving marks
Hello there y’all!
The worst thing happened to me, when I managed to spill some tea into my MacBook Pro 16'‘ (I wrote a song about it, coming soon!
I immediately put it into a tent position, and tried to dry it, then drove it to an Apple Store for diagnostics. The diagnostics revealed there is no water damage on the logic board, as I turned it topside up right away, there was some water in the trackpad and keyboard, but nothing too serious, and my computer is running fine.
ACCEPT - me turning it into a tent position caused a huge water blotch on the left side of the screen. I found some forums, suggesting to run a python script and warm up the screen, and that it would dry on it’s own. I run folding at home at 100% CPU usage for most of the time now, and I have the screen facing the heater, and the spot is dramatically reduced.
However! - It led to a kind of strange effect, as most of the water evaporated, there are no signs of it when looking directly into the screen. When I tilt the screen, or look at it at an angle, there are bright spots left after where the water had been.
What do y’all think? Will it blend? (will it dry) or is there any way to fix this?
I also found an article here, on how to replace the screen (of a non-retina Pro), with heating the glass, using suction cups to lift it, and change the screen - do you think it would be beneficial (and possible) to do the same here, with me not replacing the screen, but gently blowing air under the glass to dry? Do you have any other suggestions?
Pictures attached, the situation now, and the original spill
Bu iyi bir soru mu?
13 Yorum
Hello There! I just had a similar situation right now and I am a little worried this may be a lost cause. Since this post have you noticed any good signs of it disappearing and improving ?
Jorge Ocampo tarafından
Hello there!
well, it got a lot better since then, but there ale still some smudges in the lower left corner. Do not lose hope, yet do not count for the best. :-)
Benjamin Drápal tarafından
Hey, any news on this? How did it go?
Franz Schürmann tarafından
Hello there!
Not too much news. I am still left with a bright spot in the lower left corner, but it is slowly going away. In places where the liquid dried, the bright spots are getting less and less visible when viewed from an angle, to a point that it is basically unnoticeable until you focus on it. I hope the lower left corner dries completely as well, and if it does, I personally would not consider the screen damaged, at least so far as I need to use it.
having the same kind of trouble?
Right now I am facing the same issue,Csn I use it with spots on or will it have any future effects?
damodar reddy tarafından
8 tane daha yorum göster
