Ana içeriğe geç
Model A1059 veya A1099 / 20, 40 veya 60 GB sabit disk / dokunmaya duyarlı tıklama tekerleği
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sounds like replacing the battery would solve the problem.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
Puan 0
Yorum Ekle
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
Puan 0
1 Yorum:
please start a new post- just ask a question :)
tarafından Paylaş
Yorum Ekle
Have you tried a soft reset first to get back to the startup screen?
Puan 0
Yorum Ekle
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
Puan 0
Yorum Ekle
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
Puan 0
Yorum Ekle
tell me what i cant do
Puan 0
Yorum Ekle
Yanıtını ekle
cindy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 3,662
