Ana içeriğe geç
The Spin Master Boxer can be identified by the model number 6044290 and comes in the colors blue and black. The device is sold with 10 game activating cards, an IR remote control, and a USB charging cable.
Boxer is not going straight to front
I already received a new other product (Zoomer) because this problem, but my daughter still trying to play with Boxer. To the front our Boxer only goes to the left side, doing a turn, never going straight. But if I use the remote control to go back, it can go straight normally (only to the back). Is it a problem in the gears or in its circuit? I am thinking in maybe open it and try to fix. It is so nice to just let by side or throw away. Thank you. Michel
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Hello, just bought one doing the same. Did you ever repair yours? Trying to find a replacement motor. Thanks, Neil
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi, it seems that it is a problem with the electrical motor on that side. Try to move a little bit the wheels from that side in front direction and see if after that the wheels are rotating.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hello. I have the same problem with my boxer bot. I found that one motor is broken but I can't find what kind of motor is using. I believe is coreless micro motor 615 but the integrated pcb board on top can't identify. Can you please tell me exactly what kind of motor is? Thank you
tarafından
Yorum Ekle
Hi. I've managed to repair mine. The motor that is used in boxer is coreless micro motor 615. The odd thing was when I’ve replaced the motors, the boxer was going uncontrolled always on reverse. I don't know whay but after resoldering the motors and replacing the polarities (positive on boxer boat with negative on micro motor…and negative with positive) boxer is doing everythin as it supposed.
Puan 0
1 Yorum:
Hello. Do you have the exact ref of the motor please. Thanks
tarafından
Yorum Ekle
Yanıtını ekle
Name sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 599
