Ana içeriğe geç
32 veya 128 GB depolama seçenekleriyle sunulan 6. nesil Apple iPad Wi-Fi modeli için onarım rehberleri, söküm ve sorun giderme bilgileri. Mart 2018'de piyasaya sürülmüştür. A1893 model numarasıyla tanımlanır. 9,7 inç Retina ekran ve 64 bit A10 Fusion çipe sahiptir.
Part of screen not touch responsive after display replacement
Thank you for your guide. I’m almost finished but before closing the screen to the frame I’m testing whether the touch works. But on the unlock screen all numbers but 1, 2 and 3 work. What could cause this problem? I have installed the kapton tape on the replacement screen.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Did you unhook the battery before you took off the screen and reinstalled it? Unhook the battery and disconnect the screen connector and get a magnifying glass and see if the pins were damaged. If they are ok on both connectors than take a qtip with a little alcohol and clean the connectors then brush them off with a soft brush. Reconnect and try it again
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hey Allan Barr,
Thx for your comment, I also had small part of the touchscreen that did not responded.
Followed your steps and it’s working 100% now.
Thank you for your contribution!
Grtz
Puan 0
Yorum Ekle
Yanıtını ekle
Michel Braamhaar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 915
