Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
How to fix this boot?
Hi,
My iPhone has no previous backup and while it was on charge yesterday(the battery was flat), the Samsung adopter exploded. Its charging port was now not working. I tried to put the motherboard into another phone and it nows displays the screen but the apple sign stays on like for a minute and it restarts again to show the same thing again.
Is there any way i can fix that without loosing my data?
Thanks a lot..
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
This sounds like you have damaged one of your charging IC’s when the charger failed. This is quite common and can easily be repaired by any reputable phone repairer that offers microsoldering.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
when i changed the housing of the phone, the motherboard works in the other housing..This means that the charging IC seems to be fine..and on connecting to the cable, it opens but doesn't boot up and connect to iTunes.
If you could help please?
tarafından
@Sidick angel So it boots in the other housing and everything works?
tarafından
Yorum Ekle
You can send it to iPad rehab ipadrehab.com they can retrieve data. It costs 300 dollars only if they get the data.
Puan 0
Yorum Ekle
Solution for boot loop in IP7: https://www.youtube.com/watch?v=bQMaqHXG...
Puan 0
Yorum Ekle
Yanıtını ekle
Sidick angel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 165
