Ana içeriğe geç
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Soru Tümünü görüntüle
Display compatibility between iMac
I just got an iMac 21.5" A1418 - Late 2013 (EMC 2638) with a broken screen/LCD and i have laying around a iMac 21.5" A1418 - Late 2012 (EMC 2544) with a good screen and a bad motherboard. And I was planning to use the screen, would anyone know if the displays are compatible?
tl:dr is the EMC 2544 display, compatible on a EMC 2638?
Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
TheBookYard lists them as compatible to each other! 21.5” iMac LCD Panel & Front Glass Assembly (12/13), Apple P/N’s 661-7109, 661-7513, LG panel ID #’s LM215WF3 (SD)(D1), LM215WF3 (SD)(D3)
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
i'll give it a try and let you know, thanks!
tarafından
Installed display and everything boots ok, image and everything Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Robert G sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 906
