Why will my horn not stop sounding
How doing get to the horn switch in the airbag module?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sounds like your alarm system is setting the horn off. Use your valet key and lock the driver side door then unlock it.
Bu yanıt yardımcı oldu mu?
It sounds like the horn button on the steering wheel has the foam padding compressed and when the temperature changes it can cause the horn to go off. You will have to get a new airbag assembly or take out the horn relay or unhook the horn. This is a common problem especially if it gets cold in the area the car is.
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 200
1 Yorum
Can you explain this a little better please. I doesn't make sense.
Allan Barr tarafından
