Battery life poor even with new battery
Hi,
Even after replacing the battery in my iPad Air 2 it seems to drain quickly. I have been advised that maybe one of the pins on the battery is not making a connection and therefore not all battery cells are not in use.
Is this even possible since it works and charges as normal? Is it more likely a poor quality battery?
Thanks,
Stephen.
Bu iyi bir soru mu?
2 Yorum
Hello Usually a quick discharge after a battery change can come from two things: a poor replacement baterry or a damage main board that drains the battery. Try with a know good battery
philippe tarafından
Hi, thanks yes, probably a poor quality battery. The iPad Air 2 is quite old now, maybe i should cut my losses and upgrade.
Stephen tarafından
