Ana içeriğe geç
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
20 Soru Tümünü görüntüle
Why cooling fan runs and engine won't start?
My car was running normally then switched off the engine for a few hours, came back and while trying to start again, cooling fan runs, no crank and engine won't start.
All dashboard lights on after single click on start button while pushing breaks (cooling fan runs), which is really weird coz engine is not hot. Another press on start button, everything goes off.
I recently changed radiator and spark plugs + 2 ignition coil.
Any idea what could be the reason and how i can fix it?
Bu iyi bir soru mu?
Puan 0
5 Yorum
We’re is the bcm I’m having the same Problem
tarafından
And what all I have to tske off my part car with the same year 2007 to get this one running
tarafından
Help....I am having this same issue. What did you do to fix it?
tarafından
In my skoda fabia it was immobiliser. I just had to disconnect accu (battery) for 1 minute, then reconnect and engine started:)
tarafından
I have the same problem but I have a '94 BMW 3 series
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
It may well be that the fault with the cooling fans has drained the battery too much, when it tries to start the battery voltage collapses and the electronics give up. Try charging the battery or use a booster pack to get it started, you can then drive it somewhere to get the cooling fan problem fixed - this may well need to be a main dealer with the right diagnostics equipment.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Try to change coolant temperature sensors.the sensor send wrong information to ecu.when ecu located engine temperature high,ecu send signal to cooling fan for running.and when engine hot it not start
tarafından
Yorum Ekle
En Yararlı Yanıt
Mine did the same and it was the engine control fuse. It's in the fuse box under the
Puan 4
2 Yorum:
Under the what? I cant see the rest of the text
tarafından
Hood I think .
tarafından
Yorum Ekle
This usually an indication you have a shot BCM.
Puan 0
2 Yorum:
Where ia this located?
tarafından
BCM? What is that?
tarafından
Yorum Ekle
I’m have this problem now . The guy look at it he put a used relay on my van and now the same thing is happening. I’m going to buy a new relay and get the battery charged and see what happens.
Puan 0
1 Yorum:
Did you find out what it was?
tarafından
Yorum Ekle
It might be immobiliser. I disconnected battery for 1 min, reconnected it and the car started
Puan 0
Yorum Ekle
Anyone know why the headlights, blower motor and turn signals are all on at once without the car started?
Puan 0
1 Yorum:
You might have a ghost in that cat!!!loli had battery and alternater checked out and they are good. Relay is what I’m thinking.
tarafından
Yorum Ekle
Yanıtını ekle
Ahmad Nawar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 29
Son 7 gün: 112
Son 30 gün: 357
Her zaman: 25,538
