Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
iPhone 6s home button not working after screen replacement
Hi all,
I got a very strange problem on my iPhone 6s. My original screen broke, so I replaced the screen. After the replacement the home button is not working, neither the clicking or touch id. I put back the original screen and the home button was working on the broken screen.
I tried 3 different 6s screens and on no one worked the home button, only on the original screen. The screens are bought from different sellers so they are not the same.
What could be the problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
It has to be the screens. If it will work on the original screen but not the replacement screens and you have transferred the original home button to the the replacement screens and they are connected correctly then the only problem is the screens you purchased. I would find a higher quality screen and try it. Ifixit sells them.
Update (05/24/2020)
That's a lot of work and might not work and he will lose the warranty on the screen. I have put on quite a few screens on and have only has the issue that I had a defective screen twice. It will happen with electronics. In my opinion he just needs to buy a high quality screen and he should be fine.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Could it be that the iPhone only accepts OEM screens?
tarafından
Yorum Ekle
The original home button cable from the damaged screen can be reused with the new replacement screen. If some heat is used, the backlight layers can be taken apart, starting with the metal plate/mirror which has the home button cable enclosed inside. The process will be similar to this:
https://www.youtube.com/watch?v=01ecUhWS...
I highly recommend practicing this on a damaged screen first. Depending on what is replaced, the backlight LED power cable will need to be soldered as well.
Best of luck!
Puan 0
3 Yorum:
But I think that should not be the solution. I got again a new screen from another shop and again the home button is not working. The home button works only on the original screen.
tarafından
It might be a poor connection to the logic board. Try adding some extra padding to the flex cable before screwing down the shield.
tarafından
I tried but without success. This is very strange and really don't know what to do...
tarafından
Yorum Ekle
Yanıtını ekle
Uas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 194
