Ana içeriğe geç
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 Soru Tümünü görüntüle
No Display - TV Detects a signal
Had a xbox one that was turning on, staying black screen and then turning off after 30 seconds. Opened the console and replaced the HDMI Retimer. Put console back together and it now boots and stays on, TV recognises a source however it stays a black screen. I have tried booting to recovery mode, tried a new hard drive. Tested the 2 filters behind the HDMI port and they have continuity.
Is there any other fuses or filters that could be faulty on the HDMI circuit or is it a completely different fault all-together?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Usually turn off after 30 seconds indicates board problem or bad HDD.
But as you say it’s now staying on I’m leaning on either a dud replacement HDMI Chip (these are quite common depending on where you buy it from). Or the graphics chip APU has gone bad.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Turns out I had missed a pin I think when replacing the retimer. I reflowed it again and it started working. Turns out the HDD was dead as well.
Strange that they both went at the same time, normally it's one or the other
tarafından
Yorum Ekle
Yanıtını ekle
EvansITLtd sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 1,074
