Ana içeriğe geç
26 Ekim 2018 tarihinde piyasaya sürüldü. Modeller: A1984, A2105, A2106, A2108. GSM veya CDMA / eSIM, nano-SIM veya çift SIM seçenekleriyle; 64, 128 veya 256 GB depolama kapasitesiyle; Siyah, Beyaz, Mavi, Sarı, Mercan veya Kırmızı renk seçenekleriyle sunulmuştur. ("iPhone 10 R" şeklinde okunur.)
Which microphone is broken?
Hi, My iPhone XR microphone doesn’t work on speaker calls but works fine on normal calls.
The strange thing is that Siri works fine, (which uses the earpiece mic),… and normal phone calls work fine which i believe uses the bottom mic.
Voice memos just records static, same as speaker calls for people on the other end listening.
Front facing and Rear facing video all record sound fine..What should i be replacing here?
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The connector microphones are located on the charging port assembly. One of these microphones has become faulty. I am not sure which one handles the voice memo and speaker phone. Replace the charging port assembly and the audio should be fine.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thanks for the quick reply Chris!, ill gave that a go and report back. I had no idea the bottom had multiple mics!
tarafından
Hello please any update
I’m having the same issue
If you fixed the issue how did you do it?
tarafından
Yorum Ekle
Yanıtını ekle
s_joseph_ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 6,115
