Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
20 Soru Tümünü görüntüle
The left hinge of my MacBook is suddenly very stiff
Hello everyone!
A couple of days ago, the left hinge of my MacBook Pro started to be very stiff. If I try to close my screen, it pops back open. I first thought that there was something stuck in the hinge, but I didn’t see anything. I tried wiggling the screen a bit, but it only made it worse. I am also a bit worried that if I open the case, the hinge will be broken and instead of being stiff, it will be very loose.
I tried searching the web, but I can only find MacBooks with loose hinges instead of (1) really stiff hinge.
Has anyone seen this problem before? I hope someone can help!
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, we have seen this a few times!
Follow this guide MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement
Get some WD40 spray it into the cap to concentrate the spray into a puddle (it doesn’t take much!). Use a Cotton Swab (Q-Tip) to dip it into the cap and then wipe the gap between the hinge.
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
Thank you very much for your help!
So I just need to remove the bottom plate and I can access the hinge?
tarafından
Yes, let's first try the simple fix before we dig deeper. Don't soak it! It needs less than a drop.
tarafından
Thanks!
I have exams for school this week (at home), so I'll try it next week. I don't want to do damage when I still need my computer.
I'll get back with my result!
tarafından
It worked! Thank you very much!!
tarafından
Oh my god! It works! Thank you so so much!!! Apple was trying to charge me a whole display assembly replacement 💀
tarafından
Yorum Ekle
I doubted that this could possibly work, but I was wrong and it 100% worked! The hinge on my MacBook Pro 15" (2015 version) very quickly started to show resistance over two days about a week ago, and it's been rough ever since. It required a worrying amount of force to open and close, and it refused to stay completely closed, basically bouncing back open with about a 0.5cm gap in the front. I assumed I had somehow accidentally bent the frame and that it was not salvageable. Wrong!
I followed @danj 's instructions above, and my MacBook Pro's hinge is as good as new! I took a few photos while I had the bottom panel off in case it might help other people because the picture with "oil here" label appears to be from the screen's side, not from the bottom's side (with the logic board). Here is where I applied WD-40 with a Qtip, and I also took some time to carefully clean any dust and grime that had built up inside the case.
Thank you very much for this solution, @danj ! 🙂
(Posting as a second answer only because I can't include this image as a comment on the previous answer.)
Puan 0
1 Yorum:
Your welcome!
tarafından
Yorum Ekle
Yanıtını ekle
Bernard D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 3,078
