Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
20 Soru Tümünü görüntüle
No power, MagSafe port smells burnt
I have a MacBook Air which failed to turn on, connected the charger and got a Green then Amber MagSafe light,
Connected my neighbors charger and still no power,
I attempted an SMC reset which made the charger go from amber to Green for a moment then back to Amber
After later removing the charger I smelled a plastic burning smell from the MagSafe port on the laptop.
If anyone knows how to fix it I would greatly appreciate it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Lets give this a try, follow this guide to Step 3 MacBook Air 11" Early 2015 Battery Replacement. Now with nothing connected press the power button for a good 15 secs. Sit the system on its side so the MagSafe is on the top side carefully plug in the MagSafe charger, Did the system spontaneously boot up? If it did then you have a bad battery and will need to replace it.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Unfortunately I don’t have the screwdriver to remove the back but thank you for the advice
tarafından
Here's the needed screw drivers:
P5 Pentalobe Screwdriver Retina MacBook Pro and Air
T5 Torx Screwdriver
And you needed this tool too!
Spudger
tarafından
Yorum Ekle
Yanıtını ekle
will bevan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 235
