Ana içeriğe geç
ASUS Q536F, Mayıs 2019'da piyasaya sürülmüştür. Hem günlük kullanım hem de oyun için rakiplerine göre bütçe dostu bir seçenek olan ikisi bir arada bilgisayardır.
Back Pannel Won't Come Off
There is something holding my pack pannel on and I can't figure out how to take it off. From the outside it looks like a circle made of the same material as the panel. I can pry it open and look inside and it seems to be a screw. I can't move it as there is nowhere to place the screwdriver. It may be on the otherside underneath a keycap but from what it looks like it doesn't like up with any keys. Pressing down on it does nothing, I can't rotate the back pannel off either. Anyone know what this is and how to get it off?
Resim
Resim
Bu iyi bir soru mu?
Puan 1
5 Yorum
Hi,
Did you look under the “feet” to see if there are any screws there, holding the cover on?
tarafından
I can pry the whole thing off, its just that part in the middle that is holding onto it.
tarafından
what screwdriver did you use to open the screws?
tarafından
Maybe the screw is under the keyboard. Take out keyboard and have a look.
tarafından
https://www.youtube.com/watch?v=WW30dcvq... this model should be the same frame. if it is holding in a obviously no bottom screw area you need to pop the plastic off from the top the keyboard and remove those screws to expose the screws that you need to get at
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This is most likely a cover hiding a screw in the middle of a back panel. You can use a very small flathead screwdriver (e.g. flathead 1) to pry off the screw cover and get access to the screw head.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Braxton Biggers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 1,150
