Ana içeriğe geç
Table lamps are designed to sit on tables. They are not floor lamps, which sit on the floor. Table lamps are usually shorter than floor lamps.
Bedside LED Lamp turns on and then off in a blink
Hello everyone.
Here is my bedside lamp which has some problems, when I turn it on, it turns on just for a moment and then goes off. Which component in its circuit is probably causing this? Is it one of those 3 LEDs or that capacitor or one of those resistors?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Wow , the soldering looks bad.
Did you did anything?
Do you have a multimeter?
If so, since it has minimal components, you can actually test quick,
test the LED
Test the resistance of the resistor.
Looking at the LED, i doubt it is bad, it seems that there are bad solder in place.
I would suggest you to resolder those cold / bad solder joints first.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Erfan Monemi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 300
