Ana içeriğe geç
Car stuck in limp mode..accelerator is not responding..changed accele.
Stuck in limp mode..accelerator does nothing..changed accelerator but same thing
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You need to find the fault codes and that will give you a idea what you need to physically check. So this has a throttle sensor and you changed it and it didn't do anything. You need to test each sensor for input voltage and output voltage from the sensor to the ecm/pcm. You could have a mouse that chewed a wire. You need to find the flow chart for the trouble codes and follow them. Repairing automotive computer systems is not easy. It takes a lot of education and skill and thousands of dollars of equipment. My advice is if you aren't a trained automotive technician who specializes in diagnostic repair and has spent thousands of dollars on equipment, I would recommend taking it to a repair shop. You will probably pay more money throwing parts at it and not fixing it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
smokinsmitty.1972 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 399
