These were some basic fixes, if the problem chrome not responding still persists, try some of the following advanced methods until one of them works for you.
1. Check your internet: Check if your internet connection is working and inspect the wires from the router to your PC.
2. Chrome not closed properly, running in background: Most of the times we simply close Chrome by clicking the little cross in the corner of the window, but Chrome process keeps running in the background. Overtime these idle Chrome processes accumulate and use up all the RAM, making your PC slow and browser unresponsive. To close all the chrome.exe processes running in the background, open Task Manager> End Process (chrome.exe)
3. Reset settings/ check app conflicts: Open settings in Chrome, click advance to see all settings, scroll to Reset and clean up section, click on: update or remove incompatible applications. You can also reset Chrome to default settings here.
4. Clear browser history, cookies & cache: Clear cookies, browsing history and cache data from settings menu.
5. Uninstall and reinstall: Uninstall then reinstall Chrome; else, if a simple repair fixes the problem, it becomes much easier.
6. Disable all Chrome extensions: Under settings> more tools> extensions, disable all active extensions as they load up and make your browser functioning very heavy to process.
7. Disable firewall for chrome: If windows or any other Antivirus application’s firewall is a blocking Google Chrome, it won’t work. Allow Chrome to bypass the firewall by adding it to the exception list.
Source: https://medium.com/@mariawlarson625/how-...
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
