Ana içeriğe geç
Released November 2018 as an edition to the iPad's Pro line. Model A1980.
63 Soru Tümünü görüntüle
iPad Pro 11" Not charging after screen replacement
iPad Pro 11" Not charging after screen replacement. I replaced the screen and now the device only pulls around 0.1-0.2 from ammeter. Should I be considering replacing the battery or is there a component on the logic board possibly damaged?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Update: When I disconnect the battery the ammeter shows the device pulling the proper voltage, the device boot loops, but if I screw or hold down the battery connector while it starts booting with the battery disconnected the device powers on and appears to be charging with the proper voltage but when the screen shuts off the amperage drops and the device dies.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
I would have the tristar ic checked. Most repair shops should have a tool to test this. Did you disconnect the battery before you changed the screen? You might want to disconnect the battery for a minute and see if it resets.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Randy Northrup sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 305
