How do I flatten a removed battery?
Hi,
I’ve just finished removing my S7 edge’s battery. Due to the strong adhesive the underside of the battery comes out warped.
Since i want to reuse the battery (Which is not recommended), I have to flatten the underside so that it sits flush inside. Any ideas on how to do that?
Thank you.
Bu iyi bir soru mu?
Hi @stuig ,
There is a reason why reusing an already distorted battery is not recommended. It may become dangerous and create a fire hazard etc.
I think that you should just replace the battery as you can cause more damage and possibly more problems i.e. expenses, if you try to fix it so it fits again.
Just my $0.02 worth
jayeff tarafından
Hey @jayeff
I understand your concern, however I believe that the battery was removed without damage. (no punctures / bending).
Nvidia tarafından
