Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
Changed LCD, still no backlight.
I just ordered a new LCD, installed it, and still no backlight. Im tempted to replace my 6r8 coil, but theres no visible damage done to it (i was told that there would be corrosion or something). Can anybody help please? I have no clue what to do next.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
there are mostly two things which is dealing backlight of the lcd. one is the coil (6r8) other is the lcd itself . if you have changed the lcd then must be the coil . check the coil is damage or not ? send us the clear picture of the logic board removing shields . sometime the lcd is bad . under the flex of the lcd there is 2 prints which is soldered on the flex of the lcd that is of backlight of the lcd . check both are okay with the jack on the flex . check with the multimeter..
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
The coil looks fine to me, but heres a couple pictures, sorry, thats the best i could do. I did notice that there was a crack in a chip (it looks like it was covering a foil of some sort, and i have no clue what its for)
http://i84.photobucket.com/albums/k5/Vam...
tarafından
i will check this then will tell you soon ..
tarafından
can also be pin on LCD connection of motherboard..pin 1 ? ( I don't often work on 3gs-sorry) which is bottom row on right. so if 6r8 is ok check that pin..might just need a quick re-tin with solder to make the contact better.
tarafından
The pin? Where the number one connects at the motherboard? Doesnt that control touchscreen and backlight? My touchscreen works fine, but i will take a look at that, thanks.
tarafından
the connector on the motherboard has ?14 pairs of gold pins soldered to the board. you're looking at just 1 of them for backlight control
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
benjhake sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 1,728
