Ana içeriğe geç
Google'ın üçüncü nesil Pixel markalı akıllı telefonu ve markanın "çentikli" ilk telefonu. 6,3 inç QHD+ OLED ekran ve 64 veya 128 GB depolama alanı ile gelir. Nearly White (Beyaz), Just Black (Siyah) veya Not Pink (Pembe) renk seçenekleriyle mevcuttur.
Black Screen after Display Replacement
Hello, This google Pixel 3XL I have had a damaged lcd but the screen was still visible it was just cracked. I went to do the screen replacement and everything came off fine and there is no visible damage, but after replacing the screen the display is black but the phone is powering on, so i assumed that the new display I had received was defective, but i put on a second screen today and it is having the same issue. Any help would be greatly appreciated trying to get this running asap. Thanks.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It appears that the display would not come on completely until the back cover of the phone was put into place and the capacitive pins on the touch ID sensor were making contact, very strange issue, but once all together the problem was resolved, and the display came back on phone appears to be working fine.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Did you disconnect the battery before you removed the screen? .you could have damaged the back light circuit. Look and see if you can see anything is a darker room and shine a light on the screen. And see if you can see anything.
Update (06/11/2020)
It sounds like you might have blown a filter on the back light circuit. You should pull the board out and check the circuit. Or if this is out of you skills take it to a repair shop. You will most likely need do microsolder work.
Puan 1
4 Yorum:
The battery was disconnected before the screen was removed. I have shined a light on the screen and cant seem to see anything. It appears that there is no backlight, the screen seems to not be powering on at all but the phone is vibrating and notifications sounds are coming through.
tarafından
Update: It looks like once i had the back panel re connected with the touch id touching the capacitive pins then it brought the display on, not really sure as to why this would work but it did. Thanks for your comments, and I am a repair shop and it doesn't appear any microsolder work is needed.
tarafından
Ok. I didn't know what your skill level was. Glad you figured it out.
tarafından
Yeah it's not problem haha thanks for all the suggestions it helped me work through the problem.
tarafından
Yorum Ekle
Yanıtını ekle
Matthew Clark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 3,260
