Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
Ripped Ambient Light Sensor Face ID
Hello, I was working on another iPhone today and for the first time I ripped a flex cable. I ripped the cable connecting the ambient light sensor to the proximity and flood illumination. I was sure I have lost face ID but after booting up everything is normal. Should I just place the ripped sensor back in and call it a day? I have microsoldering skills but not great with flex cables and traces. I know that Apple disables the sensor when you replace the screen but I was just removing it to clean the glass underneath.
PS. I usually use heat to take the whole sensor assembly and plastic holder out but this time I didn’t need to transfer it over to a new screen so I tried to just pinch and remove the sensor. Noob mistake
Thanks for any help
I have included an image with a red line showing where the flex got torn.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The only option you have is solder the cable back together, put a new sensor assembly in it and lose face Id or take it to apple and have them repair it and program in a new sensor. They may try to swap out the phone if you go that route so back it up.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks for the reply. I have decided to just put the sensor back in without soldering it. I can't afford to lose face ID and having look at the ripped part its too close to the flood illuminator. I could damage that during soldering and then face ID would be dead. Everything works just not the automatic brightness control which I guess is better than having no face ID. Thanks for the comment though I appreciate it
tarafından
Yorum Ekle
Just transfer over the original ambient light sensor to a new flex cable
Puan 0
1 Yorum:
How would that work? The are one piece from the looks of it.
tarafından
Yorum Ekle
Yanıtını ekle
Tom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 4,321
