Ana içeriğe geç
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
Why did my power adapter die?
I’ve got a 85W Magsafe 2 power adapter (Model A1424). The other day it just suddenly stopped charging. No LED on the tip, and no charge indicator on my MBP. I cracked it open, because I’ve got nothing to lose and $100 to potentially save.(discharged caps of course) I’m hoping for something simple like a blown fuse or something, but I didn’t see any skid marks or obvious failures on first inspection. The components are packed pretty tightly, and there’s goop all over everything so it’s difficult to troubleshoot. The cord is in good shape (from previous experience, I’m now extra careful about straining it).
Has anybody worked on these before? Is there a part that fails frequently, or is there something I should check first? Power rails etc. Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Are you sure you have a REAL Apple unit? Don't Replace Your MacBook Charger With a Cheap Knockoff
tarafından
@danj Yes I am sure.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Have you tested the Magsafe on another Mac? This could be a logic board issue. The main reason magsafes fail is the lead and you can usually see it.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Boy I sure hope it isn't the Mac. Sadly I don't have another to test with.
tarafından
I took my Mac to Apple service where they plugged it in to one of their power supplies, and it charged fine.
tarafından
Yorum Ekle
Yanıtını ekle
Joe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 357
