Ana içeriğe geç
The second generation (chassis model L30) was an American market-only version, again styled by Nissan's California design center under Doug Wilson through 1994 (design freeze in 1995).
Will turn over no start
I have a 1999 Nissan Altima Gxe 2.4L engine. The crank will turn over but want start. Have already changed the spark plugs, spark plug wires, distributor cap and rotor. I also just changed the valve cover gasket cause it was leaking and changed oil and filter. It wouldn't start before i did the tune up and valve cover gasket change.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Yes. Changed spark plugs, spark plug wires, distributor cap and rotor. It wouldn't start before I did the tuneup on it. Would turn over but not start
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Did you check for spark and fuel? Did you check the timing belt and make sure it was on time? First steps before you do anything else.
Update (06/24/2020)
You need to see if it has spark and fuel pressure. You need to check and see if the timing belt is broken. There are multiple reasons a car will not start.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
How do you check the fuel pressure
tarafından
My advice is take it to a shop
tarafından
Yorum Ekle
Are you sure the car doesn't have an inertia cut-out, which has tripped (they are designed to turn the engine off in case of accident)? I am not familiar with this car specifically, but the switches are sometimes found in the vicinity of the spare wheel well.
Puan 0
Yorum Ekle
Yanıtını ekle
Sean Harkins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 436
