Ana içeriğe geç
26 Ekim 2018'de piyasaya sürüldü. A1984,A2105,A2106,A2108 Modelleri ile bilinir. GSM veya CDMA/eSIM , nano-SIM veya dual-SIM / 64, 128, veya 256 GB / Siyah, Beyaz, Mavi, Sarı, Mercan veya Kırmızı. ("iPhone 10 R." olarak telaffuz edilir.)
468 Soru Tümünü görüntüle
Screen Unresponsive, Ghost Touch
My daughter's iPhone XR started developing some weird symptoms where without input, it opens up apps, scrolls between screens, etc... After some googling, found that this is referred to as ghost touch or something. Couldn't find what the fix is to this problem though.
I tried resetting the iPhone to factory settings, even tried doing a reset/restore in DFU mode, to no avail. I wanna say this is maybe a hardware issue with the display (digitizer/glass) more so than a software issue. She had a case on it from day 1 but did drop it a few times, and even had a small crack on the screen towards one corner, not too bad though.
This being the case, I'm willing to replace the display myself, but before I shell out $100 on a new one, I wanted to see if anybody else experienced this issue and if so, did replacing the display fix the problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
I'm having this exact same issue. Phone is pretty much useless right now. Keeps swiping constantly between apps and clicking whatever is at the bottom of the screen. Did you ever replace the screen, and if so did it fix the issue?
tarafından
Replacing the display assembly fixed the problem.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You can buy a good quality screen for a iPhone XR for around 50 dollars. My guess is the dropping and possibly the crack can cause these issues. I would try replacing the screen.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Yes a new screen should fix the problem.
tarafından
Yorum Ekle
A new screen has not fixed my issue
Puan 0
Yorum Ekle
Yanıtını ekle
Jose sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,603
