Charging port not snug
The charging cable is very loose in the phone charging port. Can I get parts to replace the port on my Droid Turbo Power/
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 321
Did you check with a different cable? micro-usb is kind of designed that the cable fails rather then port. If still problem:
Search in eBay (depends on the country)...
Markus2 tarafından
@markus2 Thanks for your answer. I have tried other cables and still have the same problem. The cables work on other phones.
Robert Bruns tarafından
Well then in eBay.com you can find the charging port around $4. Of course, there are perhaps no manuals for charging port replacement: Start with Motorola Droid Turbo batarya değişimi
May be it helps.
Markus2 tarafından
