Ana içeriğe geç
Guides and repair information for KitchenAid mixers.
My motor won't turn.
I have a K45ss mixer w/ a Hobart motor. I’m fixing it up,cleaned,painted, greased and new cord. It worked before I started but now it wont’t turn . I have 120v to the speed control ,I took out the brushes out when painting and covered the holes with a foam. The brushes don’t spark or meet the standards to replace (over a half inch long) and I have tried putting them in different positions to no avail. I can turn the mixer by hand also. Any ideas ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
To state the obvious, something happened between disassembly and reassembly. This link takes you to the Service Manual for your mixer:
++http://www.kitchenaidparts.eu/documents/...
Things to consider:
The brushes have a chamfer on one corner. This must clear a stop in the brush holder. Take a flashlight and look into the holder and make sure the brush is aligned before inserting it.
Are all the wires attached to the proper tabs on the control board?
Is the link that pushes on the control plate properly positioned. This link also actuates the on-off switch on the control board.
The Service Manual will help you make sure that everything is in its proper place.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Paul Doering sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 224
