Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Soru Tümünü görüntüle
iMac 2008 screen issue (not backlight)
I purchased a 2008 iMac and have a problem with the screen. The screen stays black but chime and fans start when pressing the on button. There is a light coming from the back of the screen which is how I know the backlight is working but there is nothing appearing on the screen.
can someone help me on ways to diagnose this problem? I am a newbie.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
If you are seeing a white light glow around the screen then your backlight is working all you are seeing is the lights leakage! To prove that take a strong flashlight place it on the screen at a sharp angle the light aiming in would allow you to see a faint image of your desk top and its icons.
- If you see the desktop and its icons that would imply the backlight has failed.
The other test you can do is plug in an external display via the Mini-DVI connection on the back using the needed adapter to convert it to what ever your external display offers.
- If you don’t see an image that would imply your logic board has failed.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Chad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 66
