Ana içeriğe geç
iMac G4 için onarım bilgileri.
iMac G4 neck opening tool
Hi guys,
I am looking for a tool (or the best work-around) for opening the screws of the iMac G4 silver neck. I have opened it before with screwdrivers and bits, but it was a real pain and I would love a solid tool for doing it again.
Thank you,
Lucas
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
@lucaswars2 - What are you trying to do?
I don't remember needing to take the neck apart for any repairs.
tarafından
@danj It’s not traveling smoothly anymore and I’m trying to see if I can clean the inside up a bit or put a new plastic bracket in to make it smoother...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Apple doesn’t offer the sub components that makes up the neck. Here’s one source for the needed part:
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thanks, but I don't need a replacement part, I just need a tool to open the neck with...
tarafından
In that case you'll need to make a custom tool. A piece of brass rod should do it drill the three holes into the brass rod (handle) and using some steel pins of the correct diameter press fitted should do the trick.
tarafından
Yorum Ekle
Yanıtını ekle
Lucas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 635
