Ana içeriğe geç
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Soru Tümünü görüntüle
iPhone 7 Plus keeps searching for service
I received an iPhone 7 Plus to repair and resell. It isn’t set up yet, but it keeps searching for a signal, while the sim card isn't inserted. Inserting a sim card doesn't make a difference though, it keeps searching for a signal. When I try to set the phone up, it tells me "Unable to Activate" (see the picture below). Does anyone know what the problem might be and what I should check? What should I check with my multimeter? Is this the baseband chip that's causing problems? I am new to logic board repair / micro soldering, but I do want to do it myself and I got the equipment.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Your phone has more than likely had a failed audio IC repair. The audio IC has had too much heat applied to it causing the Baseband CPU’s solder balls to expand resulting in the problem you are having.
This has nothing to do with the Antenna. If you type *#06# into your keypad does the IMEI display? If it doesn’t it will confirm it. There is no simple fix for this problem unless you are an experienced microsolderer.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Check the antenna bars. They might be obstructed.
If that doesn’t work, try ejecting, cleaning, and re-inserting the SIM card.
I personally don’t have 7 plus, so this is some minor textbook stuff that not everyone knows.
Puan 0
1 Yorum:
The antenna bars do look a bit damaged. Could this be the problem?
https://imgur.com/xS9aTJD
tarafından
Yorum Ekle
Yanıtını ekle
Max sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 82
