Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
20 Soru Tümünü görüntüle
MacBook not turning on and no charger indication
Hi all, I have a MacBook Air (Model A1466 EMC 2925) that is completely unresponsive regardless of whether it is plugged in or not. The power button does nothing and when plugging in a charger there is no LED charging indicator. I have Cleaned the charger and port as well as plugging the charger into another macbook where it worked as normal. I have removed and replugged the battery as well as attempting an SMC reset (although I’m not sure the SMC reset worked). I have also done a voltage check on the battery I/O pins and pins 1&4 as well as pins 2&4 both have around 2.5V however the the battery is supposed to have a 7.6V output. Is there a way to test the battery pins to discern whether the problem is with the battery or not, a way to test the charger to battery continuity or anything else I can try?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It’s possible your I/O board is borked or something on your logic board.
I like Louis Rossmann’s videos about this:
https://youtu.be/PoMmVtGXjyE
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
MrMcMonkeyMan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 73
