Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
My New Battery upon input is making Sparks?
So, I recently purchased a new macbook battery, and removed the old one with ease. After using the adhesive to remove glue and the like, I also added some alcohol to wipe the area and clean up any additional adhesive.
When I went to put the new battery in, I pressed the connector onto the board and while trying to lightly put the cells into place, I noticed a few sparks on the right side of the battery - I immediately stopped. A small cloud of smoke could be seen as well.
I let everything dry, and did not expect this to happen, could it be a faulty battery? Did I install the battery wrong? I figured the new one should not be doing this at all. I’m wondering if I let the battery discharge (how would I do that safely?) I could just come back to it and move it around.
What should I do to continue the installation, ( I haven’t even screwed the screws back in for the battery)?
Thanks for any assistance :)
Bu iyi bir soru mu?
Puan 0
3 Yorum
Where did you buy the battery?
tarafından
@danj Right here at good 'ole Ifixit. The battery ended up not sparking anymore. But, as I tried to lightly press it down so the adhesive would stick to the bottom of the laptop I noticed fumes and the cell I had my hand on became very hot. So I stopped. Will probably just ask for a replacement.
tarafından
Yes! That makes sense!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
usually sparks/smoke from these batteries come from punctures and the layers of the battery reacting with each other. If something conductive, like metal, is bridging the layers you will get that reaction as well.
Its probably best to get another battery as that one is a potential fire hazard, and could damage your laptop as well in the future.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Sal Elosa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 449
