Samsung S9 Plus Battery Replacement
Hello everyone,
After replacing the Samsung Galaxy S9 Plus battery do I need to buy a rear cover adhesive to strip my phone? If yes, where can I buy it?
Thank you in advance!
Bu iyi bir soru mu?
Hello everyone,
Bu iyi bir soru mu?
Hi,
Just to be on the safe side, I would get another cover. You can get one right here on iFixit for $5.62. Replace it if it became damaged after you opened the phone or if looks like it needs it.
Bu yanıt yardımcı oldu mu?
Hello Duarte
You need adhesive for the battery and for the glass cover.
If you don't replace the adhesive, it will come loose. Remember not to wet the terminal after opening it.
Gradually heat the glass lid and use a card or some plastic object to open it. Look at the tutorial to see what you can damage if you insert the tool a lot.
Hey Duarte,
I agree with Alexander. You can pick up a replacement glass panel (includes adhesive) here at iFixIt for $16.99.
I can’t find the rear adhesive kit, which would include all of the adhesives related to the rear panel. There is one available for the S9, but not the S9+. As long as you are careful in removing the rear cover, and follow the steps to disconnect the cables serving the camera and fingerprint sensor, you should be OK with just the adhesive. There are other sites that offer the adhesive, I’d just search for Galaxy S9+ Rear Glass Panel Adhesive.
In the spirit of transparency, and since this is my first answer (haven’t been blasted for providing external links) - I recommend Amazon for this part. You can find a good kit here. It includes a back cover, preinstalled lens cover (w/ adhesive) and adhesive preinstalled for the fingerprint sensor. I don’t see these on iFixit, so I don’t feel terrible about sending you out into the wild for the search for parts.
-Tom
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 899
