Ana içeriğe geç
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
70 Soru Tümünü görüntüle
Screen flashing and touch problems after replacement
After replacing the screen on a Pixel 3a, the screen will flash (like a single bright strobe) when waking the phone up or sometimes when opening an app. Also, some screen taps are missed and entering text has to be done slowly to prevent missed letters.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
It sounds like a bad connection. Disconnect the battery and unhook the screen and make sure that there are no bent pins. I would then clean the connectors with a qtip and alcohol and a soft brush. Put it back together and hook up the battery last
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hello, Brandon! Did you manage to find a solution?
Puan 0
Yorum Ekle
Yanıtını ekle
Brandon Ankeny sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 807
