Searching or No Signal
After doing a battery install I have a iPhone X that won’t get service it either says “no service” or “searching” it does recognize if a sim is installed or removed.
i have done every reset possible, different sims, put original battery back in. Replaced the antenna cable bracket(With flex) on bottom, I also replaced the loud speaker flex (also known as interconnect flex cable ) being the cell antenna bracket connects to it. Still same issue. Anyone have any idea? Thanks
Bu iyi bir soru mu?
Does it bring up the IMEI number on the keypad if you input *#06#
Chris Stables tarafından
@imicrosoldering Yes it does
Drew Butera tarafından
@Andrew Butera Not sure what the problem could be. If it is not the sim card or your network and it is not a baseband issue I would be looking at the sim tray holder. Check the pins with a magnifying glass not much other help I can give without it on my bench.
@imicrosoldering ok i will give that a shot, thank you very much for the help!
Have you found a solution?
Christopher Synco tarafından
