Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
iPhone X bootloop problem after screen and battery remplacement
Hi,
two weeks before i changed the screen and the battery and both worked good untill last day i found that my iphone x battery was drained ,
i put it in the charger than the problem of boot loop began and keep restarting untill it return to the battery low level icon , i was able to enter into dfu and recovery mode but my mac didn't detect the phone !!
i tried to bootup with the old battery without face id flex cable and yes it works!! the phone bootup normally then i made a backup , after the backup i restarted the phone and the problem of bootloop returns again and the battery drained again
my questions are, where is the problem in this situation ? is it the screen or the battery ? and how i can fix this problem ? what if i get a new battery and make the restore with should it will works ?
Thank you guys :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Check the proximity/flood sensor/earpiece speaker cable and see if the cable is damaged or on if the sensors are damaged. You may need a new assembly for the above parts. If you change it face Id will not work after. It doesn't make sense if it was the battery because you tried it with the old battery. I would try the assembly. You can buy one from ifixit or fixez.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Amine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 132
