Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
NO Touch ID, NO pressure sensing - Home Button not working
Hi!
iPhone 7 after a hard fall does not see home button anymore.
I have a screen with good working home button so I know the home button works but when i attach screen the home button not works. NO touch ID, no Pressure sensing nothing….
Can someone point me in the direction what to check on the PCB board please? Thank you.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
From the 7 series up you cannot replace the home button with another one. It will not work unless it is a universal home button. If it is not a universal home button it will not function for anything it will only be cosmetic. There are two main reasons your home button has stopped functioning.
1.       The home button assembly has been damaged.
2.       The home button flex assembly on the screen has been damaged.
I doubt there would be a faulty component on the logic board.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
No other home button will return touch ID functionality other than the original home button that came with your phone.
Does the button look damaged? If not, it could be the cable or connector that plugs into the home button is damaged. This isnt usually the case, but it’s worth a shot to remove the original home button from the screen and install it on a new screen to test.
If that does not work, the only option to regain touch ID functionality it to take it to an Apple store. In the past, they have been able to replace the home button and reprogram it to restore touch ID functionality.
Puan 1
2 Yorum:
Yes I know that. But The Home button completley not working.. if I press or tap on it does not return to the home screen. Assistive touch Automatically scwitching on
tarafından
If you took another home button from another phone the Touch ID will not work but any other functionality of the Home button will work. But in my case nothing happening. Thats why I assume there is a problem on the PCB
tarafından
Yorum Ekle
Yanıtını ekle
Peter Hupuczi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 184
