I have a De’Longhi all in one machine model # Bco 330T
The coffee maker portion of the machine is not heating up, I don’t hear the coil heating the water. The espresso maker portion works fine is this repairable?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
After doing some research, apparently this is a common issue with this brand. So, there is a central heating plate that heats the water for the espresso side and brewing side. The thermostat on the plate goes out and thermostat fuse gets blown. I will link a YouTube repair video below that explains this. Even though the model is a little bit different, it will be the same concept. I hope this helps. DeLonghi BCO430 Coffee Maker *WON'T BREW* *FIXED*
I apologize, the video has a model with a separate plate for the brewing side. This is why I felt it would be the most helpful for you.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 2,141
@pchris330 - If you need to make corrections go to the Options tab to make the edit or if you need to add information you can also create a new Answer entry when you save it will ask you if you want to post as an update.
Dan tarafından
I have the same problem. It appears that the clock/coffee maker is a separate circuit or board than the espresso half. This morning the clock and coffee maker portion won't operate. (I should add that the machine has lasted for 6 years with daily+ use so it is long past any warranty or extended warranty.) I see there is a repair video link with a similar model in the answer. If I can figure this out I will author a repair guide for this model, as I don't see one yet.
L- B tarafından
