Ana içeriğe geç
Repair guides and information for the Nintendo Switch Joy-Con controllers.
Ribbon lock joycon Left
I replaced the stick on two of my joy cons. One was successfully fixed. My second one, had the gray ribbon connector lock come off completely and I can't seem to get it back on. Is this salvageable.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello Virgilio,
I assume you mean the little ‘flap‘ you use to secure the connector in place. It’s there to put pressure onto the ribbon cable to make sure it’s making a good contact. If you have still have the “gray ribbon connector lock“ intact, it can indeed be placed back, however, I would not recommend doing this without a microscope else you’re risking damaging the connector even more. Now, it’s not necessary to have the ‘flap‘ there. You could instead use a small piece of thin plastic sheet and stick in under the ribbon (in between the ribbon and the connector) to put pressure onto said ribbon. Once in place and verify if it’s working and put some glue over the connector to secure it in place. There’s plenty of tutorials on how to do this on YouTube
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks a bunch! This was really helpful!
tarafından
Thank you. I give u big kith. You are my wallet's savior.
tarafından
Yorum Ekle
Yanıtını ekle
Virgilio Ocampo Jr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 3,737
