AC/DC adapter for the DYSON DC35, what is the polarity of the plug?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If you have the adapter you can test to see which blade of the plug is not powered.
Looking at a picture of the plug itself on the web I can see that the outer barrel of the adapter is (-) so using a continuity tester with one probe on the outer barrel, move between the 2 blades until you get a signal, that blade of the plug is neutral and the other will be positive giving you the polarity.
If you do not have the adapter you can attempt to match to the configuration shown in this photo or just buy a replacement.
Bu yanıt yardımcı oldu mu?
It appears to have two positive contacts. The center most pin is 16.75V+and the middle circle is 24.35V+, the outermost contact is negative
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 531
