Ana içeriğe geç
Restarts every 3 minutes because of thermalmonitord
Restarts every 3 minutes, Panic-full logs mention "missing sensor(s): Prs0”
Panic full log: https://pastebin.com/MVKxS4h4
This phone has had the screen and housing replaced, people on reddit suggested changing the battery but that didn’t fix it, thinking of changing the lightning port flex cable. any idea about where exactly is the “Prs0“ sensor?
Thank you, any help is greatly appreciated.
Bu iyi bir soru mu?
Puan 13
6 Yorum
The dock flex cable needs to be replaced. The cable must be original!
tarafından
I have an A1901 iPhone X 256 which had a swollen battery. It was working fine, then I took it to the Apple Store and they screwed it up. They replaced the battery but now the phone only stays on for a few minutes and goes to the white apple logo. It does this repeatedly. I was able to incrementally recover images using a fresh Photos library then importing photos from the connected device 3 minutes at a time. 4000+ images! 24GB! I have not been able to find another suitable conduit utility to retrieve other information. They spend too much time analyzing then the phone times out and restarts. We have no back up otherwise and remembering or resetting every password on the new phone setup is aggravating. Again, other than the battery, there was nothing wrong before Apple broke the device. While Apple is willing to swap phones, we don't want to let the data go until we try everything.
tarafından
how did this work out for you? same position... june 2022, iphone xs max. was it the flex cable? did you just *gasp* restore to factory?
tarafından
I have this kind of panicfull error
"panicString" : "panic (cpu 1 caller Oxfffffff01cd8b878): userspace watchdog timeout:
no successful checkins from thermalmonitord since load nservice returned not alive
with context : is_alive_func returned unhealthy : current 5fffffffff, mask 3fffffffff,
expected 3fffffffff. SD: 1 BC: 1 RC: 0 BS: 1, Missing sensor(s): Prs0 Inservice:
backboardd, total successful checkins since load (180 seconds ago):” i tried replacing charging flex with other original flex also i tried replacing original flash flex then too i gets retarted at 180 secs
tarafından
hi man,
Same is the case with my iphone X,
How you fixed it, please guide me.
Regards
cityspotpk@gmail.com
tarafından
1 tane daha yorum göster
Yorum Ekle
12 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's a sensor that's on charger port on original called "thermalmoniord" this sensor is not on the generic charger ports that are sold. The "thermalmoniord" when missing the phone counts down 3 minutes then reboots.
The way you can check if it's the sensor it's looking for is look at the error log on the phone or keep locking and unlocking the phone. If the phone doesn't reboot it's because the generic charger port don't have a thermalmoniord sensor on it.
Bu yanıt yardımcı oldu mu?
Puan 14
9 Yorum:
Thanks for that info Albert.
tarafından
@imicrosoldering You're most welcome.
tarafından
But this problem is with the genuine apple flex cable that came with this iphone.
previously, I noticed that if I use it for 2 minutes and then keep it locked for a few minutes then the countdown would be reset and the phone would start counting down again, I disassembled the phone to find the problem but then after I reassembled the phone, I noticed that now even after I lock the phone, the countdown doesn’t reset anymore, it will restart the phone even if it’s locked, with the screen off, not sure why
tarafından
@jawad_ Much like the other iPhone models, updating the apps and iOS on your iPhone often fixes a restart problem. If the problem happens to be with a more recent update, hook up to your iTunes store and restore your iPhone to a previous backup.
tarafından
@jawad_ get a new one and replace the old one it may be faulty
tarafından
4 tane daha yorum göster
Yorum Ekle
Hi,
A very common issue with the iPhone X series and 11, is a tiny bit of water landing on the proximity sensor. This usually causes the phone to reboot all the time.
The proximity sensor is on the flex cable that has the earspeaker attached to it.
Simply disconect it, and leave it disconected for now. Boot the phone and see if the phone still reboots after 3 min. If it does not, then that is probably the issue. Replace the proximity flex cable.
Note: the proxi is part of the faceid circuit and you will loose that functionality, if you replace that part. You can transfer or repair the original proxi if you can micro solder.
If disconecting the proxi did not fix it, disconect everything besides the screen, battery, and power button. Boot the phone and test for bootloop.
If the bootloop is gone, start recconecting parts one by one while testing for bootloop. You will find the part at fault.
If it still bootloops disconect the power button and connect the port instead, and prompt to boot via the port and test again.
If the problem is still there, you have narrowed it down to the motherboard.
I hope this helps
Puan 6
Yorum Ekle
prso is a pressure sensor usually on the charging flex
Puan 4
1 Yorum:
Hello, can you tell where this sensor/chip located in iPhone x charging port? Is it microphone?
tarafından
Yorum Ekle
Barometric Pressure Sensor on Port
Puan 3
1 Yorum:
tarafından
Yorum Ekle
Just an update to this, replaced charging flex and power flex and both errors gone.
Puan 2
3 Yorum:
Did you have the missing prs0 and mic0 sensor? Or just the prs0 - I’ve just had the charge flex replaced and it still comes up with the missing prs0
tarafından
Hi mwr_allen, where you bought both power flex and charging flex? If we use non genuine flexes, will the problem persist?
tarafından
it can also be caused by the vibrator motor, charging flex. volume keys flex mute flex power button flex. they are all linked to each other via i2c communitcation data lines
tarafından
Yorum Ekle
My son’s iPhone X started rebooting every 3 minutes. It started a few ago. He used it fine the night before and on Wednesday morning he started to use it and it began rebooting. I started investigating it and discovered the thermal messages in the log file. It’s referencing mic 1. I have an appointment at the apple store later today. Apple told me that they believe it was the motherboard and it would be an out of warranty repair. I installed Panic Log Analyzer and it says Possible issues: Charging Port Flex and Power Button Flex
panic(cpu 0 caller 0xfffffff013ff70f4): userspace watchdog timeout: no successful checkins from thermalmonitord since load
service returned not alive with context : is_alive_func returned unhealthy : current 73fffffffff, mask 67fffffffff, expected 67fffffffff. SD: 1
BC: 1 Missing sensor(s): mic1
Puan 2
1 Yorum:
Hello I currently have this exact issue did the replacements work?
tarafından
Yorum Ekle
I have the same panic after 3 minutes and reads both mic2 and Prs0 in log.
will this mean both the power/flash flex and charging port are fried?
Puan 1
4 Yorum:
Yes, this would indicate that both are fried. Have you replaced the back glass? Or the complete housing? It's been seen that the laser machines cut these flexes, if the stencil is not "perfectly" aligned. However, try replacing the charge flex first and see if the error persists, if so, change power flex :)
tarafından
Yes the back glass was replaced, when removing the power flex I found the bottom solder points were lifted so re-soldered and replaced but that was before the panic showing both errors.
I had also replaced the charging flex with another genuine flex but potentially this one was also no good so I’ve ordered a couple of replacement genuine charging flex’s and another genuine power flex so will test once arrived and check log again.
I don’t use a laser machine, just remove screen, battery, rear and front cameras and board and a heat gun upside down so I have both hands free to work and usually I use it at around 350 degrees c but with this one I used 400 but I’ve done loads of these in the past and never had this issue but hey ho, you live and learn I suppose.?
tarafından
Yeah okay - i guess it's just bad luck..:) sometimes s**t happens - and Yeah, we learn every day, glad it's fixed..:)
tarafından
well u get solution for this ma bro??..coz i have one same casses..
tarafından
Yorum Ekle
PRSO means a problem with to pressure sensor that is on charging flex. Replace with good dock flex otherwise, the problem can't be fixed. The same problem that I got on iPhone 12 pro max with the same restart on 3 minutes problem with that log. I replace it with from doner iPhone and the problem was solved. If you use new aftermarket be aware of good quality. You can try flex from iFixit.
Puan 1
Yorum Ekle
How do you guys read the logs? I
Have a 12 pro max, replaced the battery… phone started rebooting after.. if its locked it stays on but if we began to use it starts rebooting
Puan 1
Yorum Ekle
Something happened to me when I was repairing the iPhone X
I damaged a piece of the main camera's FPC connector and in the upper left corner of the main circuit board a piece of the plating is gone (copper shows through).
The device works perfectly except for one error that I couldn't find anything about on the Internet: A kernel panic with thermalmonitored error and missing sensor TP1A
I couldn't find anything about the TP1A. It will probably be near the camera connection? After unplugging all components, the error still occurs and the device restarts every 3 minutes. But there was a short time when loading, the device didn't restart for 1 hour?
Could someone enlighten me more about the TP1A?
Puan 0
1 Yorum:
Or is TP1A a Battery Issue? I just read that in a Chinese forum, I hope so. So can someone help me before I get a new battery?
tarafından
Yorum Ekle
Can some show where the sensor is physically located on the flex cable?
When doing full houding repair I often break the original flex when removing. Physically no visible damage but I see to break the sensor. How to avoid this when removing the flex?
Puan 0
Yorum Ekle
had this with 6s, just a loose connector
Puan 0
Yorum Ekle
Yanıtını ekle
jawad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 75
Son 7 gün: 499
Son 30 gün: 2,115
Her zaman: 89,691
