Ana içeriğe geç
2015 Mart ayında duyurulan ve 10 Nisan 2015’te piyasaya sürülen Galaxy S6, Galaxy serisinin önde gelen ürünüdür. Kavisli ekran versiyonu Galaxy S6 Edge olarak bilinir.
Samsung S6 won’t turn on only showing (white led)
I’ve tried most key combos. I’m going to take this explanation from DroidGuy because it matches my exact problem. “I have a Samsung Galaxy S6. I had it hooked up to the charger all night, woke up the next morning, saw that the battery icon was full and green. When I went to turn it on, the whole screen went black and I have not been able to get it running again since. I tried all the troubleshooting there is, still nothing. The only thing that happened is a solid white LED light.“ The phone has a lot of sentimental value to me and it’s not an option to take to the store help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
you fix this? i have the same problem
tarafından
I’ve just found my old Galaxy again which has this exact problem. Still no way to fix this?
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have this problem on the s6 edge+. phone boots up and after a minute it freezes and then shuts down or restarts with the white led on. Cannot use it for more than a minute unless i constantly engage the digitiser(by drawing a 0 on the screen or in a pencil erasing motion). So i’m guessing this issue could be a display shorting or something related to the display connector.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
try using another charger or if that doesnt work do a master reset usually when u gimet the white light its a sign battery is dead
Puan 0
2 Yorum:
Hi... I have the same issue ... but in desperation I banged it a little then it worked for few hours and now it’s back to the white solid light ... I tried the same trick again and it is just stuck at the Samsung boot up screen. Frustrated ... wonder if someone can help please as I also have a lot of memories saved up in that phone and I don’t want to completely erase it until I have the memories backed up. Any help please ?
tarafından
has anyone figured out what the solution is
tarafından
Yorum Ekle
After you turn on the phone, you don't need to do anything. After a period of time, the device may be able to boot normally. This is one method I have tried.
Puan 0
Yorum Ekle
It happened to me now and it happened previously. Just wait for the charging to end and then it will open
Puan 0
1 Yorum:
sorry what do you mean, charge it fully then it will turn on? thanks
tarafından
Yorum Ekle
This problem is related to a hardware issue.
Could range anything from NAND/UFS failure or issues with the RAM or anything.
Samsung hasn't documented anything on this.
I'm still working out what it could mean.
Puan 0
Yorum Ekle
Yanıtını ekle
Fix S6 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 19
Son 30 gün: 90
Her zaman: 10,256
