Ana içeriğe geç
20 Eylül 2019'da piyasaya sürülen, isteğe bağlı hücresel bağlantı özelliğine sahip Apple'ın beşinci nesil akıllı saati.
Display without digitizer stays black
I recently bought a series 5 with broken display glass. I was able to separate the broken glass and digitizer from the display succesfully.
At first I thought the display was broken after the separation since it stayed black. But at some point the battery died and suddenly the display showed the following image:
Resim
After charging for a while, the watch turned on and went into black screen again and stayed black.
I am currently waiting for the replacement digitizer to arrive, but I assume the series 5 is showing a black screen, when no digitizer is connected.
Can anyone confirm this behaviour?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Did you ever figure this out?
I have a friend who has a series 5 that works fine, but the screen has two scratches.
How hard was it to separate the digitizer from the LCD?
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If this is happening, there is either something stuck in the screen connector, the LCD cables are damaged, or one of the pins on the screen is bent out of place.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi Franqus, I am having the same problem. Removed the glass (and by accident the digitizer) and now there is no image....
Did you manage to revive your Oled display?
Thank you
Puan 1
Yorum Ekle
My Apple Watch 5 was working fine. I took it off to take a bath and when I went to put it on my arm the display was black and showed the time only. I shows a red low battery but it was fully charged before. Any suggestions?
Puan 0
Yorum Ekle
Hi, I have the same problem. Did the new digitizer help?
Puan 0
1 Yorum:
Did you finalize fixed the display? Or just replaced entirely by a new one?
tarafından
Yorum Ekle
Same as @lucianolavigne . I stripped a part of the cable that connects the digitizer so I need to replace it. Can anyone confirm if the display should at least turn on if I remove the digitizer? I just want to see if it is working before doing/buying anything else.
Puan 0
Yorum Ekle
Hi, i hv that series 5 with black display and time don't know what happened. Never dropped cracked broken or opened.
Anybody want ot for parts or hv a solution kindly hit me up. I'm frm Pakistan.
Resim
Puan 0
Yorum Ekle
Yanıtını ekle
franqus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,243
