Ana içeriğe geç
Repair guides and support for cars and trucks by Dodge.
Soru Kapandı
How do I fix a broken fuel gauge
fuel gauge on 1993 dodge dakota stays on empty, even when full.
Bu iyi bir soru mu?
Puan 0
2 Yorum
Answered on answers.
tarafından
This question was migrated from http://meta.ifixit.com/Answers.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This is a pretty common and annoying problem with the Dakotas'. Most likely it is the sending unit. You will have to drop the fuel tank and replace the fuel pump/filter assembly The sender, filter, and pump are all one assembly, so you'll need to buy a whole new pump assembly to change the sender. Of course you can, and should, also check your gauge to make sure that it is working okay. Use a meter to check your sending unit and see if you have any output. If that checks out, its your gauge. Here is a pretty good write up about how to do it....Hope this helps, good Luck.
Bu yanıt yardımcı oldu mu?
Puan 9
6 Yorum:
Sad but true and not cheap. +
tarafından
Good to know! I looked up the price of the unit (pump/filter assembly)$80-$250, depending on where you want to buy it, etc. I also look up EVERYTHING on Youtube, and it is an easy fix for the Do-It-Yourselfer!
tarafından
mí Dakota 98 consume demasiado combustible
tarafından
no e tenido respuesta
tarafından
What yoh post to set the fuel pump too
tarafından
1 tane daha yorum göster
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,474
