Ana içeriğe geç
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Soru Tümünü görüntüle
Why has my reception been bad since I replaced the rear housing?
I recently replaced the rear housing of my iphone 8 plus and I now have really bad reception compared to other iphone 8 pluses on the same carrier. I broke the top antenna flex cable but have now replaced that but still have bad reception. Is the antenna itself located in the rear housing and would that be why I don’t have as good reception? - (when i say reception i only mean cellular reception, wifi has been absolutely fine)
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I had a look and one of the bracket connectors had snapped, so I replaced that and it’s working beautifully
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Is the housing original or aftermarket? Some aftermarket housings may not have proper connections to use the housing as an antenna.
I’ve read in some posts that adding a bit of solder on the connection points on the housing may solve the problem. Correct me if I’m wrong.
Puan 4
Yorum Ekle
Yanıtını ekle
Oliver Davies sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 7
Her zaman: 88
