Power LED doesn't light up
IHave a desktop emachines model 1831
The Power LED Doesn’t light up?
Can I buy that LED here?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Does the computer turn on and work OK and it is only the Power LED that does not light up or doesn't the computer even start?
If the computer turns on and works OK but it is only the Power LED that is the problem, check that Power LED cable wires that may be in the Front Panel I/O cable are securely connected to the header pins on the motherboard.
There should be a set of Front Panel I/O header pins on the motherboard. These should include connections for the Power button, the Power LED and the HDD LED
It should be printed on the motherboard as to what the header pins are used for and how the cables are connected e.g. +ve PWR LED , +ve HDD LED and PWR for the power button
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 491
